![]() | Home > Puma (Tdci) > Just appeared on the GTR: SSM40851 |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Defender Front and Rear Propshaft Grease Points
Models : LD - Defender Title: Defender Front and Rear Propshaft Grease Points Last Modified: 30-MAR-2009 08:27 Category: Noise/ Vibration Symptom: 703000 Vibration Concerns Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles. Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Nice one ED
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Thanks!!
silverpig Member Since: 16 Nov 2008 Location: York Posts: 6 ![]() ![]() ![]() |
Top man Eduardo thanks again
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
Mine were loose. The probles is that the ones for the UJ“s are so hidden you need to rotate them to plug the grease pistol!
I“m wondering, how does LR realize about all these issues! The nipples hasn`t been a big issue on any forum! Puma 110" SW ............................................................. Earth first. Other planets later |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
A mine of information as usual. Must check this weekend. Thanks Eduardo. Me thinks we should be subscribing to you! 1982 88" 2.25 diesel
Your welcome friends.
My subscriptions end in June (if I remember) and possibly I will suscribe again (It is worth its weight in gold). If not, please can somebody take the flag? Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Rob A Member Since: 06 Feb 2009 Location: Sao Paulo Posts: 29 ![]() ![]() ![]() |
Thanks for the tip Ed Just out of interest, how does the subscription work. Is it ridiculously expensive? 130 HCPU 2.4TDCi 110 300TDi |
Hi
You must be suscribe to the GTR. Cost around US$300 per year for the internet access to the database including workshop manuals and all the bulletins. You can suscribe for a day, a week or a month. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thanks Ed Just one more question: If you suscribe for a week (or even a day) can you download stuff from the GTTR. In other words copy all you want from the workshop manuals to your own computer? ![]() cheers Rob 130 HCPU 2.4TDCi 110 300TDi |
Bundubasher Member Since: 25 Sep 2008 Location: Sandton Posts: 34 ![]() ![]() ![]() |
Hi Rob. Yes you need a lot of paper and maybe a spare ink cartridge. Or you can use a free PDF file creator from pdfforge.net. Then instead of printing to your printer you print to the PDF file creator. Then save the PDF files in folders. You can then print them anytime you want.
Regards Anthony |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 ![]() ![]() |
This, I suspect, is the cause of the infamous 'grooling' sound discussed elsewhere on the forum, LR have replaced a good number of rear diffs because of these missing grease points. I know mine(diff) was replaced. |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
I spent many hours dowloading all the ws and electrical manuals and put them into pdfs on a day subscription. if anyone needs one give me a shout.
Hi there,
In fact a lot of us have donwloaded the GTR information in PDF (far better than have a lot of paper)to future reference But the appareance of this new SSMs convince me to extend my subscription for 1 year. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
