Home > Puma (Tdci) > 2.2 TDCI sluggish after head gasket replacement
Page 2 of 2 <12
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
It was a bad inj, and we also found out part of the overheat issue was an aftermarket radiator.
We swapped the injs, one problem solved, then we troubleshot the coolant system and found the allisport rad was causin an issue at 120kph. But all speeds below are perfect.
We are using the stock rad with viscous fan spacer soft spring thermostat and at 120kph we are gettin 83-87c, and with the ac on it gets up to 92c. Acceptable in my books compared to before... Can't leave well enough alone
Post #926778 22nd Oct 2021 1:19pm
Page 2 of 2 <12
