Home > Puma (Tdci) > Aaggh! Rear seat bolts |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 |
All
I’m really struggling to find RYG500960 which are the M8x18 torq bolts with washer which the ones that attach the forward facing rear seats to the tub. Apparently JLR are not making them anymore. I assume these are high tensile given their role and so am hesitant to just use any M8 bolts. Any thoughts/sources/alternatives are greatly received as I want to get the seats in (previous owner removed, I’ve got another pair from here to go in 👍) Thanks as always Dicky 2.4TDCI 90 - everyday brilliance S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
20th Oct 2021 5:25pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1777 |
Any socket head "Allen bolt" should be 10.8 strength, but as they're only going into captive mild steel inserts I cannot imagine properly installed std 8.8 bolts would fail.
Keith |
20th Oct 2021 5:36pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3409 |
Maybe use AYG100240 .... but these are M8x25. They are the used for attaching the rear end of the tub to the chassis. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
20th Oct 2021 6:18pm |
BYG000060 should also be M8x25 torx screw, used for rear door hinge (body side). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
20th Oct 2021 6:20pm |
Thanks Chaps, this is why I love this forum! Off to get some different bolts, then seats in this weekend 👍👍 2.4TDCI 90 - everyday brilliance
20th Oct 2021 7:09pm |
