Home > Puma (Tdci) > Aaggh! Rear seat bolts
Minch90
All
I’m really struggling to find RYG500960 which are the M8x18 torq bolts with washer which the ones that attach the forward facing rear seats to the tub. Apparently JLR are not making them anymore.
I assume these are high tensile given their role and so am hesitant to just use any M8 bolts. Any thoughts/sources/alternatives are greatly received as I want to get the seats in (previous owner removed, I’ve got another pair from here to go in 👍)
Thanks as always
Dicky 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #926527 20th Oct 2021 5:25pm
ickle
Any socket head "Allen bolt" should be 10.8 strength, but as they're only going into captive mild steel inserts I cannot imagine properly installed std 8.8 bolts would fail.
Keith
Post #926528 20th Oct 2021 5:36pm
DSC-off
Just type "M8 x 20 torx" or "M8 x 20 Cap Screw" in your preferred Web search tool.
Add some plain 8mm washers to the order.
They're nothing special
Post #926529 20th Oct 2021 5:36pm
Dinnu
Maybe use AYG100240 .... but these are M8x25. They are the used for attaching the rear end of the tub to the chassis. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926532 20th Oct 2021 6:18pm
Dinnu
BYG000060 should also be M8x25 torx screw, used for rear door hinge (body side). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926534 20th Oct 2021 6:20pm
Minch90
Thanks Chaps, this is why I love this forum! Off to get some different bolts, then seats in this weekend 👍👍 2.4TDCI 90 - everyday brilliance
Post #926551 20th Oct 2021 7:09pm
