Home > Technical > Trailer electrics |
The usual solution is an adjustable flasher relay that allows for the variable load of some LED and some incandescent bulbs. Checking the earths is always a good call, though. Darren
14th Oct 2021 9:37am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
normal filament bulbs will always appear to flash slower than LED lights (well flashing at the same rate but with a lag) due to the warm-up time of the bulbs. There is nothing wrong here, just how it works.
Assuming the vehicle has the correct flasher unit fitted to go with the LED lights, there should be an adjuster on it which allows you to tweak the current at which the trailer warning light illuminates. You can have a tweak of this with/without the trailer connected to see if that solves the issue. From memory I think you are meant to turn it back so the warning light has just gone off without the trailer connected. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
14th Oct 2021 9:46am |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
And just to add to that - make sure you do the adjustment with the engine running. Dave
Green Goddess - 1998 Defender 110 300tdi |
14th Oct 2021 10:00am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20578 |
Agree with all of the above, and the reason for adjustment with the engine running is due to the slightly increased voltage with the alternator running and engine running.
KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
14th Oct 2021 12:04pm |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Thanks all much appreciated, will have a look and a play at the weekend.
14th Oct 2021 12:20pm |
Thanks again everyone, adjustable flasher fixed it....
16th Oct 2021 8:06am |
