Home > Off Topic > Ultrasonic cleaning baths
Page 2 of 2 <12
SteveG
2005 Defender 90 Td5 CSW Belize Green
I bought the 30L about 4 years ago - no problems so far. As you say they all look the same, from the various sellers.
I found the key to good results was to use hot water, and a good quality degreaser - bilthamber surefex HD in my case. Then results are very good. Most parts only needed one good run, and a quick brush and a second pass if you had really stubborn bits in recesses,
Getting the largest size you can afford is best.
cheers, Steve
Post #925480 13th Oct 2021 7:47am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Getting baskets for a unit will give you improved results. Also for small parts you don’t need 30l of solvent. Water in the tank and a glass beaker of solvent works just as well. Kerry tanks were good if you can find a second hand one. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #925493 13th Oct 2021 10:56am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Thanks folks, lots of helpful advice there.
Post #925518 13th Oct 2021 1:39pm
Ramsay wrote:
... Also for small parts you don’t need 30l of solvent. Water in the tank and a glass beaker of solvent works just as well. ...
This also keeps the tank's interior clean and is well worth doing whenever possible.
Post #925542 13th Oct 2021 4:31pm
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
we used to use them in BG when i worked there to clean heat exchangers on combi boilers - joe you may know this if your a plumber, they were ok when used with the specific cleaning solution, but we gave up in the end as they didnt clean tight spaces so the hardened sludge couldnt be removed from everywhere needed, this was on plate heat exchangers which have tiny water ways
Pete
Post #925633 14th Oct 2021 2:13pm
Page 2 of 2 <12
