Home > Off Topic > Ultrasonic cleaning baths |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 631 |
Getting baskets for a unit will give you improved results. Also for small parts you don’t need 30l of solvent. Water in the tank and a glass beaker of solvent works just as well. Kerry tanks were good if you can find a second hand one. 1995 Defender 110 CSW
1971 SIIA Lightweight |
13th Oct 2021 10:56am |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 910 |
Thanks folks, lots of helpful advice there.
13th Oct 2021 1:39pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17543 |
This also keeps the tank's interior clean and is well worth doing whenever possible. |
13th Oct 2021 4:31pm |
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 |
we used to use them in BG when i worked there to clean heat exchangers on combi boilers - joe you may know this if your a plumber, they were ok when used with the specific cleaning solution, but we gave up in the end as they didnt clean tight spaces so the hardened sludge couldnt be removed from everywhere needed, this was on plate heat exchangers which have tiny water ways
Pete |
14th Oct 2021 2:13pm |
