Home > Technical > Indicator cancelling prematurely due to rubber gaiter
PeteCrenshaw
Australia 2006 Defender 110 2.5 TD XS CSW Chawton White
Common problem: my indicator stalk cancels prematurely when indicating right. I'm 110% sure that it's due to the rubber gaiter/boot/grommet, since the stalk works perfectly when the gaiter is retracted.
Do you guys have any fix for this? I think it's because the gaiter is stretched when indicating right and essentially pulls the stalk back down.
Also, bending the stalk downwards didn't work for me - made no difference whatsoever Sad
Post #925317 11th Oct 2021 3:06pm
Litch
Put a nick in the rubber where the stalk comes through, worked for me. ONE LIFE, GET IT!
Post #925346 11th Oct 2021 6:56pm
markb110
How many kids do you have...... Whistle
Post #925347 11th Oct 2021 7:03pm
PeteCrenshaw
Thanks for the tip Very Happy Would you be able to post a photo? I can't quite visualise it.
Haha none, why?
Post #925369 12th Oct 2021 12:26am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
have you had the steering wheel off lately? if so you may have not got the blue plastic cancelling strip at the right angle. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #925382 12th Oct 2021 7:26am
PeteCrenshaw
[quote="jeffersj"]
Yes I did, but I made sure the arrow on the ring pointed to the left (i.e. indicator stalk). It also works totally fine if the gaiter isn't hooked into the cowl.
Post #925385 12th Oct 2021 7:29am
