![]() | Home > Puma (Tdci) > 2.4 Tdci PUMA, VCV, SYMPTOMS & FITTING |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 834 ![]() ![]() ![]() |
Great write up i have one to fit (just need time) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
It should be fine after that, mine did the same when I replaced mine. Although I used one from PF Jones, cost £45 and came in a Genuine Nissan box but was the correct part and has worked really well.
No problems since and full performance is back. ![]() ⛽️🛢️⚙️🧰💪 |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4263 ![]() ![]() ![]() |
I’m a bit concerned about the longevity of the Denso part. I put one in maybe 25,000 miles ago and it is already showing signs of failure again with a slightly uneven idle. 2007 110 TDCi Station Wagon XS
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17729 ![]() ![]() ![]() |
Premature failure of the VCV could well be caused by moisture or dirt in the fuel. If you ever suspect that you have excess moisture in the fuel, expect to have to change the VCV.
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
I changed mine today. There was absolutely no chance (for me) to remove the VCV without removing other parts. Engine was running unstable at low rpms when cold, but cured itself when warm. Everithing ok now...well let's hope it stays so.😉
![]() Click image to enlarge Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
