Home > Technical > Windshield wipers not working. 1994 defender 90 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
Check that the wiper spindles are not seized. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
3rd Oct 2021 6:59am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
unplug the loom from the motor and see if you have +ve and -ve power to the plug, if you do then its the motor or wiper system that needs attention.
dont rush to buy a new motor until you have taken the plug off and checked , also as others have said it may have just stalled due to friction somewhere in the system, and new motor brushs are also available parts are generally interchangeable across the British Leyland range so parts are not a problem DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
3rd Oct 2021 7:11am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
The wiper stalk can also be finished, they wear out frequently, if its not any of the other issues. Cheap enough to replace Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
3rd Oct 2021 8:37am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5223 |
or the wiper switch itself on the motor.
Some times a gentle tug on the wiper arm itself, after you switch the stalk down, may get them going again. Just case the switch itself is stuck Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
4th Oct 2021 4:36am |
