Home > Maintenance & Modifications > Footwell repair panels |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
My left hand footwell has rusted through around the air con drain pipe. I’ve managed to hack it out to about a fist sized hole. Unfortunately the rust creeps up past the inner wing brackets but does not seem to have spread very far down. It has however eaten away at the ribs in the steel.
I want to make a repair that looks as close to original as possible but can only find these with the ribs: https://www.lrbulkheads.co.uk/Land-Rover-9...ing-PAIR-1 Ideally, I only need a repair panel like this: https://yrmit.co.uk/product/lhs-extended-f...-defender/ Plus the inner skin. Does anyone do the outer skin with ribs (just the left side) and the inner skin, but with pre cut holes for air con? Thanks James 2002 110 td5 Last edited by Jimb1978 on 28th Sep 2021 6:38pm. Edited 2 times in total |
28th Sep 2021 6:26pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3394 |
Check out this post: https://www.defender2.net/forum/topic77923.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
28th Sep 2021 6:31pm |
Not an option to cut the AC holes before or after fitting? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
28th Sep 2021 6:51pm |
Yes, I guess I was just hoping for an easy way to get them in the right place. There isn’t much left of mine to take a measurement from
I was also planning on just cutting out the bare minimum and trying to use only as much of the new panels as needed. Considering the bulkhead is 20 years old it really is on lovely condition apart from this little bit 2002 110 td5 |
28th Sep 2021 6:58pm |
Unfortunately away from home for a while, otherwise would had been happy to measure them up for you. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
29th Sep 2021 6:56am |
I thought I’d give a bit of an update. I’m on the home straight of this job now after three days of pain. I’ve managed to do it without taking the wing off so I guess that’s a positive. I couldn’t wait for the ribbed panels so used yrm.
Thanks for all the help and offers of measuring up. Obligatory pics… [img][/img] Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2002 110 td5 |
25th Oct 2021 4:30pm |
Not sure why photos shears get posted in reverse order 2002 110 td5
25th Oct 2021 4:31pm |
Great job
Perhaps consider one of those mud shields to protect the footwell from stone chips, such as made by Gwyn Lewis. Or you can make yours, as the previous owner of my Defender made. They work great in protecting the footwell. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
26th Oct 2021 10:59am |
