![]() | Home > In Car Electronics > Advice for just a good radio |
Probably something like one of the blaupunkt professional lorry head units and a decent ariel
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
Keep the radio you have and fit an FM Radio Antenna Signal Amplifier they are as cheap as chips well about £5.00 and will certainly do the job of boosting the radio signal. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
For the sake of a few quid I will try the signal booster first - thanks8
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3535 ![]() ![]() ![]() |
I was sick of the "Seek PI" - see thread https://www.defender2.net/forum/topic72713.html
Please keep us posted if the amplifier made a difference or not. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8213 ![]() ![]() ![]() |
this fills my needs too as all i want is radio and better signal. which amplifier did you get? Cheers
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 ![]() ![]() ![]() |
I'm delighted with this:
![]() Click image to enlarge Louder than the engine, plays radio 4, holds stations well, even in terrible signal areas, and sounds just fine on original LR aerial and original 300 tdi speakers. No tape, no CD but does have a front and rear USB; the latter is fed back thro the dash to a BlueSea extension from MUD to the lower switch panel to charge things. The Bluetooth for the phone (for streaming if you do that) is flawless. Knocks the Alpine I had in the more recent Defender out of the park. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold Last edited by Ihod on 23rd Sep 2021 8:17am. Edited 1 time in total |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4260 ![]() ![]() ![]() |
I like how simple that looks, my pioneer looks like an 80s arcade machine with tiny buttons and an illogical menu system.
Are Blaupunkt still trading? There online presence is a bit patchy. 2007 110 TDCi Station Wagon XS |
They go in and out of stock on Amazon for about £100 and it was a tenner for the external mic that I have routed thro' to the top of the steering column.
Its been faultless - and suits the dash nicely. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
I wish I'd seen that before I replaced my original radio. New one has tiny buttons with labels that are impossible to read while driving. Lots of flashing lights to keep morons entertained, but apart from that unusable.
Worse still, the brightness doesn't adjust automatically. You're either blinded at night or the screen's unreadable by day. |
So here is and update.
A £5-95 signal booster arrived and was duly fitted. There was no real difference so I decided to fit a new wing aerial. With the new aerial and the signal booster, there was an improvement, but not enough to avoid my loss of signal frustrations. I now decided to bite the bullet and go for a new radio. My choice was based on your advice here, to go for a heavy duty Blaupunkt, and after seeing the Blaupunkt Dublin 112BT (above) I started searching. I could not find one in stock, so went for a Blaupunkt DOHA 112BT ![]() Click image to enlarge fitted it this morning, really is a plug and play two minute job to fit and very easy to set up. Well, I am so impressed ![]() Thank you all for your advice. It was refreshing to discover that not everyone wants a Double din, sub woofer HiFi system. We all have different needs at the end of the day. My wife says my needs are "special" Thanks again |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Lessur,
Does the display auto dim when you turn the sidelights/headlights on? Defender 90 XS TD5 (03 Reg) |
Not automatic,
You can manually adjust the brightness. |
Thanks Defender 90 XS TD5 (03 Reg)
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
Blaupunkt (Blue Point) have had a reputation for clean, uncomplicated, easy to use head units. No bells and whistles, just a solid unit.
It was part of the Bosch group, but was sold off, asset striped, liquidated and reborn, I believe some of the products are made under licence using just the name. They still keep the plain, professional look for their headunits which is a good thing. VDO/Continental have a similar "Pro" range of headunits : https://www.continental-automotive.com/en-...fotainment Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
