Home > In Car Electronics > Advice for just a good radio |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
Was also think that the Breman mechless would be a great covert upgrade on my 110 puma, especially since it can be illumination colour matched to to the instrument green. Just shaken by the price tag so would like to see one in the flesh before committing. Might just have to save up for one. Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
1st Mar 2022 2:29pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I think Grafty put one in their classic Range Rover, it’s in the bold thread, it looked pretty decent.
1st Mar 2022 6:35pm |
cocker Member Since: 23 Sep 2021 Location: Merseyside Posts: 38 |
Hi also thinking of changing my radio due to poor reception and like the look of the Blaupunkt Dublin 112BT unit to remove my radio do i have to remove the centre consul (dash top off to get to the screws ) or just the piece round the radio which does not fit properly at the bottom as you can see in the photo
help appreciated Peter Click image to enlarge |
2nd Mar 2022 5:01pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
Below
2nd Mar 2022 9:04pm |
If you have the correct release tools you don’t need to remove either the wonky piece of trim or centre console to remove the radio. You can make the poorly fitting aperture fit better by bending the wires behind it but you’ll probably need to take the whole centre console out to do that. A word to the wise - poor radio reception usually has more to do with a bad aerial than it does a bad radio. On tractors and combines with a plastic roof or where aerials are mounted to wing mirrors, reception is significantly improved by earthing the base of the aerial straight to the battery or a known good earth. We know how bad the earths can be on Land Rovers! |
2nd Mar 2022 9:06pm |
