Home > Technical > Defender security |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
Welcome to the forum. Drop a hello up and some photo's (away from your house!!) we all love a photo.
With regard to the above, it's very, very well covered in the forum. Do a search using the search function above for security and do some reading through and you'll start to get an idea of the "layers" approach. Once you've had a read shout if anything doesn't make sense. But the search function is your friend for this one. |
21st Sep 2021 9:24am |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 |
Take a look at this site...
https://www.landroverdefendersecurity.com/ As previously stated you need 'layers'... some visible and some not. |
21st Sep 2021 9:33am |
As mentioned above and like when hiking in the mountains, layers are key
What you decide upon is obviously up to you, but I would suggest not sharing the details around too much. The good news is that as with the Defender itself, security is utterly adaptable to your own circumstances and requirements. How about that for a vague answer The first step you have already taken, being aware and thinking about it |
21st Sep 2021 10:11am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 319 |
Hiya, I have just invested in an X Defender Gear Stick Lock for my 110. I'm in no doubt that a very determined thief would get it off given the time but it serves as a visual deterrent and it stows away easily in the centre cubby.
You fit it with 5th gear selected and it mean that it is impossible to change gear or shift to neutral. Certainly worth a look, we chose it because of the cost, bulk and complication of pedal locks. Cheers, Martin |
22nd Sep 2021 1:02pm |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Just trying to get my head round this ^^^^^ Low range, anti-stall, bit of throttle and away you go isn't it?
Would locked in neutral be better so no possibility of any drive???? |
22nd Sep 2021 3:35pm |
The lock goes over the range lever and the main gear lever so it’s locked in high range, 5th gear. So, you can’t drive it and you can’t tow it…I hope.
22nd Sep 2021 3:43pm |
Ah ok that kills the low range idea at least.
22nd Sep 2021 3:55pm |
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 |
[img]https://www.defender2.net/gallery/albums/userpics/23575/normal_PXL_20210922_163519569.jpg[/img]
[img]https://www.defender2.net/gallery/albums/userpics/23575/normal_PXL_20210922_163511352.jpg[/img] [img]https://www.defender2.net/gallery/albums/userpics/23575/normal_PXL_20210922_163316735.jpg[/img] [img]https://www.defender2.net/gallery/albums/userpics/23575/normal_PXL_20210913_085608849.jpg[/img] [img]https://www.defender2.net/gallery/albums/userpics/23575/normal_PXL_20210913_085544796.jpg[/img] [img]https://www.defender2.net/gallery/albums/userpics/23575/normal_PXL_20210913_085553957.jpg[/img] I don't have a drive or footpath so parked on the road outside the house but I have Skytag live ,A peddle lock, Clifford alarm and this what the last owner made which is great for nipping in the garage whilst paying for fuel etc as a deterrent as well as locking the wheel it just rests at the side so easy reach to quickly put on and take off. Last edited by kaney on 24th Sep 2021 4:13pm. Edited 2 times in total |
22nd Sep 2021 5:55pm |
No pics in your gallery I'm afraid, kaney. Darren
22nd Sep 2021 7:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
Towing it would be a little easier that you probably want to know, however it will act as good deterrent and would hopefully make the scumbags look for easier pickings. It is, sadly, not easy to make any classic LR difficult to tow away. The most effective methods are to block it in, or to fit a good quality wheel-clamp. Most transmission-based devices are depressingly easy to circumvent. Any security device is an uneasy compromise between making the vehicle harder to pinch and making the vehicle unusable for you. Devices which are difficult or time-consuming to fit and remove tend, after a while, to be left off, and that becomes self-defeating. |
22nd Sep 2021 11:39pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge
When I have a look there is no idea why I will try again to put them on but last time it just had writing on when I clicked it as looked like a link it did not open. Click image to enlarge Last edited by kaney on 24th Sep 2021 4:06pm. Edited 1 time in total |
23rd Sep 2021 4:14pm |
Click image to enlarge That's odd. When I copy and re-post your text link between new 'IMG' tags, it appears. You haven't inadvertently ticked the 'Disable BBCode in this post' on the 'Post a reply' page, by any chance? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Sep 2021 8:02am |
Thanks I have gone into my profile and ticked a few boxes to yes
Click image to enlarge And you are correct as now editing as the picture is showing |
24th Sep 2021 4:08pm |
