Home > Maintenance & Modifications > 2.4 TDCI power issue
Page 1 of 3 123>
Rivarama
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
New issue coming up on my low mileage 2.4 Puma… (makes me wonder why I even bothered looking for a low mileage example in the first place)
On my way to the LRO show, I experienced a loss of power on the highway. After cruising for 45min in 6th gear at 70mph, I suddenly started to lose power and the car slowed down gradually and wouldn’t rev above 2k rpm… managed to limp to the next exit gradually shifting gears down to 3rd at 25mph and waited for AA to take the car back home on a flat bed.
The AA guy read the ECU which flagged a boost error code. We inspected the boost pipes for holes, but we could not find any. We also ruled out a problem w the turbo as the car operated just fine for the first 45min, and there was no sign of smoke when the power went.
I drove the car again for the past couple of days on short distance and low speed and it was OK. However I took the car on the motorway again, and after 10min cruising at 70mph it happened again. I stopped on the hard shoulder, turned the engine off for 1min, removed the key, started again and everything went back to normal.
No warning on the dash at anytime… very strange.
After reading similar posts on the forum, it sounds like there could be a few potential culprits :
- MAF sensor
- VCV
- boost pipes (holes) - though the prob should happen all the time if they were punctured
- turbo / actuator? (How likely?)
Anything else you guys can think of based on the above symptoms?
Also - how difficult are those jobs for a novice DIYer?
Post #921364 13th Sep 2021 9:13pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Check coolant level. If the car believes it’s getting too hot it can go into limp, had it on an old one of mine after a while of motorway work… the error codes can last a while.
Had a tdi Passat that would limp on occasion, worked out it was when I’d accelerated then lifted quickly. Mechanic said turbo worn so slightly out of perimeter for ecu, solution was to turn on/ off on the fly, fun in the fast lane of the M3! Always worked though…!
Worth trying..
Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #921368 13th Sep 2021 9:53pm
Alex's call is a good one. If it thinks it's overheating (even if it's not) then it goes into limp mode to protect itself, which is exactly what you've described. Once it's cooled, or thinks it has, then normal service is resumed. Unfortunately, there are many and varied reasons why this might be happening, a lot of which won't flag obvious or indeed any fault codes. This includes, at one extreme, a head gasket failure as reported by somebody here only a couple of weeks ago, to at the other a duff cylinder head temp (CHT) sensor.
Other potential failures could be the water pump or the viscous fan coupling, or even a partially blocked radiator, either inside or out.
Were there any other symptoms when it happened such as the temp gauge rising or the temp gauge immediately going to maximum and then dropping off? Darren
Post #921389 14th Sep 2021 7:25am
Rivarama
Thanks for the input both. The list is scary !! I would to avoid fixing 10thi gs in the hope it could be that 😝
As for the the temperature, it all sat happily under the half way point throughout and the coolant level is sitting perfectly on the midpoint of the tank.
I am not convinced it has anything to do with the temperature, as an engine switch off/in makes the issue disappear…
Will investigate the booster pipes thoroughly and proceed to the next steps (I guess from the least costly to the more costly??)
Post #921396 14th Sep 2021 8:27am
hank
Is the error code 'over boost' or 'under boost' ?
Sounds like an overboost due to gummed up turbo vanes.
Read the following
https://www.defender2.net/forum/post561963.html
https://www.defender2.net/forum/topic62985.html > 110 XS Double Cab
Post #921402 14th Sep 2021 9:22am
Minch90
I’ve had this three times and agree with all above and more. Mine is a ‘58 2.4 bought at 19k now 54k.
First time was water pump leakage (behaved as described for a couple of weeks, then failure (all coolant on the road).
Next was dirty fuel filter due to leaky breather pipe, no power, turn on/off and all is good again.
Third was knackered vcv and sticky turbo. Short trips don’t help this so I’m lead to believe. Anyway new MAF, VCV and spray turbo cleaner stuff and all is good again.
What the 4th time will be I don’t know. I do use periodic injector cleaner, routine Millers and periodic turbo cleaner now as mine does 19mi twice daily 4 days a week, oh and any opportunity for a longer cross country run 👍 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #921437 14th Sep 2021 12:39pm
Merlin
A friend of mine had exactly the same problem. He went through all the bits, as above, and eventually found the solution was mud blocking the radiator. He said it was blocking some sensor and hence the ECU thought it was overheating. He cleared the mud between the two radiators and its been ok since. Hope that helps. Peter PS he said it was a long and difficult job.
Post #921585 15th Sep 2021 10:45am
Caterham
Just a thought.
if low mileage and 'looked after' perhaps through not giving it plenty of beans the turbo vanes are rather dirty and acuator isn't working correctly?
does it have egr blanked off?
Post #921623 15th Sep 2021 5:39pm
Rivarama
I have bought a bottle of Forte turbo cleaner which I will pour and burn this week end before I move to the next stage (cleaning turbo / vanes).
But to make matter more complicated, one of my series 2a has decided to annoy me as well, and I need to take the rocker shaft out this week and clean everything on the shaft as a rocker lubrication issue just popped up… Land Rover for you hey ?!?
Post #921675 16th Sep 2021 6:49am
Rivarama
Read the following
I just plugged my cheap OBDII reader on the ECU and it did come up w a P0299 code: turbo super charger under boost.
It looks like it could indeed be due to gummed up vanes.
I drove the car for about 1h yesterday in a congested area without any problem, and 15min after I finally got on the motorway and started cruising at 70mph, i lost power again (scary on the m25). The strange thing is that I could rev the engine normally when I was shifting the gear into neutral (still rolling at 50mph speed) but as soon as I would engage a gear again, the revs wouldn’t go past 2000rpm and the car would just slow down.
Post #921882 18th Sep 2021 7:34am
Nitroneil
I had identical symptoms on my 110 2.4 double cab. Took garage quite a while to find problem but it turned out to be leaking head gasket. 90S D250 fuji and loving it.
Post #921883 18th Sep 2021 7:44am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Literally just had the same issue on mine tonight was at 120kph lifted off accelerator and you could tell no power. Sometimes lifting accelerator and re applying resolves the issue.
But not this time, managed to coast to the next exit, cycled the power and engine would rev fine started off again and could tell low power.
The following codes were stored for mine
P0100
P0404
P02A4
P1103
P0299
Now I cleaned the codes restarted the engine it sounded like it missed fit a couple of seconds then idle was fine. Made the rest of the 60km home in 5th gear at 100kph a d to ensure I could feel it if I lost power, no issues no loss of power on them 60km it’s not predictable at all.
Have a vcv valve that I’ll prob try to fit tomorrow and monitor to see if that helps. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #921935 18th Sep 2021 9:35pm
Rivarama
Sorry to hear that you experienced that issue. Let us know how the VCV replacement turns out (pm me a couple of pics if you don’t mind).
Post #921937 18th Sep 2021 10:08pm
Rivarama
Ok, so I watched a few videos of the Mr Muscle oven cleaner application to clear the carbon gunk.
The problem is that - being an absolute novice on defenders - I have got no clue as to how I work my way around the 2.4 turbo.
From the videos, people recommend spraying Mr Muscle from the exhaust pipe side… if I got this right, it would involve removing the 4 bolts highlighted on the picture below?
Although the bolts can be accessed from the top, do you have any tips to hold the nut in place on the other side as 3 of them don’t seems accessible (even from underneath)
Also, does the heat shield need to be removed?
Thank you
Post #921939 18th Sep 2021 10:19pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
I also had this problem, in my case it was the head gasket.
I would get a RELD head gasket leak test kit as next step and confirm it either way before you fill the turbo with mr muscle.
https://www.amazon.co.uk/RELD-Cylinder-Com...NrPXRydWU=
Post #921942 19th Sep 2021 5:22am
Page 1 of 3 123>
