Home > Td5 > Started smoking? |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 378 |
Mine has the same problem. Smoked when I accelerated hard.
When it went in for a service, they could find nothing wrong. So I did 3 things. Firstly I put expensive non supermarket diesel in it , then I put some Wynns injector cleaner in it , and also thrashed it ( for a Defender) down the A12 for about 5 miles. This cured it. Sadly I did all three at the same time, so I don’t know which one cured it. I will say it’s now running beautifully as well👍🏻 2002 td5 90 county hardtop |
11th Sep 2021 11:59am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
Yes, mine smokes when it boosts. I usually drive it like i've stolen it so getting a good thrash isn't a problem.
I usually use shell or esso fuel in it, will try the injector cleaner. thanks. |
11th Sep 2021 1:20pm |
