Home > Technical > Rear shocks turning
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Rear shocks turning
Having an MOT done and tester says the rear shocks can be twisted if turned by hand. Advised to tighten the nut at the bottom of each and if that doesn’t work to change the bushes at the bottom. This is with the car raised.
Is this a thing? Or are they meant to be tight so they cannot be turned?
Post #920804 10th Sep 2021 7:39am
Bluest
As long as there's no play in the bottom bushes I don't see why being able to rotate the shock body is a problem. Maybe he is suggesting it is getting loose in the bottom bushes and to think about changing them. 2007 110 TDCi Station Wagon XS
Post #920807 10th Sep 2021 7:43am
kmac
Yeah there is no play. Will see if he fails it for that. He is writing it up now.
Post #920809 10th Sep 2021 7:53am
kmac
Ok passed MOT but included an advisory that "bushes slightly worn but not resulting in excessive movement"
Going to change the bushes before they get worse
Post #920830 10th Sep 2021 10:18am
kmac
What is better - poly bushes or rubber?
Any recommended manufacturer for poly?
Post #920831 10th Sep 2021 10:20am
Dinnu
Re: Rear shocks turning
The lower nut/washer is tightened against a step. I use rubber, very cheap, very easy to replace. Opportunity to look under the truck. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920837 10th Sep 2021 10:49am
landy andy
Do not over tighten the bottom pins/nuts. You will either get though bottom bushes, or snap off the pin when using the articulation.
Post #920960 11th Sep 2021 5:37am
kmac
Thanks for the tip LandayAndy - was just going to replace with rubber bushes and tighten to torque in Service Manual
Dinnu - what do you mean by tightened against a step?
Post #921007 11th Sep 2021 10:28am
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
Hi,
The pins on a shock are 2 different diameters, a plain part and a slightly smaller threaded part.
The inner washer, bushes and centre washers slide over the plain part, and the outer washer and nut tighten up against the step and stop the bushes from being over compressed.
As per the image below.
Hope that helps, Paul
Post #921162 12th Sep 2021 1:47pm
landy andy
I personally disagree with the above comment and would say the threaded part allows adjustment depending on what you are fitting it too. Even in defenders they have different setups with some axles having bush retaining cups on and some not. You want just enough pressure on the bushes that there is no slack/play. Gwyn Lewis (suspension guru) talked me through this.
But I’m sure we all have different methods.
Post #921171 12th Sep 2021 2:50pm
