Home > Technical > Electrical puzzle |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Evening chaps .. I have a tad of an electrical puzzle..
I’ve wired up my carling switches and all working ok .. except the illumination with side lights on .. I’ve connected to one of the light circuits and have power to the leads for the switches..run a daisy chain link to all switches all have power yet nothing on the switches as in no light . I’ve run a power cable to the switches and they all work .. So I can’t work out why nothing from the cable that has power .. ? |
5th Sep 2021 6:47pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Has each switch got an earth also? Need that for the switch illumination to work
5th Sep 2021 8:49pm |
Morning .. yes mate each switch is earthed ..
6th Sep 2021 6:03am |
It’s a five pin carling.
On off eu switch Pin 8 is side light when I put 12 v through it the light lights However have connected the side lights and have power yes the switches don’t light up . Click image to enlarge Click image to enlarge Click image to enlarge |
6th Sep 2021 10:33am |
i can not find carling eu switch type but carling contura V type look to match it
your switch have two Led pdf for lamps circuit and switch circuit circuit code 1 shows on and off switch pin out (have looked at your switch pic with 2 and 3 linked ? ) https://www.defender2.net/gallery/albums/u...le0017.PDF now having looked at lamp circuit D/4 with circuit code 1 a link to hole carling switch Catalog PDF 50mb see below https://1drv.ms/b/s!AtZSoWFHDgnGlkwLcd6OadeQIKvk?e=uhsjVk |
6th Sep 2021 1:41pm |
Click image to enlarge Here is the wiring information . Yes and sorry it’s a cordura . It’s wired as per the first one.where 3 is linked to 2 and 8 is the live light feed . As I’ve mention the switches work as they should .. apart from the internal light . If I put a live feed to 8 the green illumination light works . I’ve linked the live feed for the lights to the dash I’ve power all along the daisy chain of wire but when I attach it the green light doesn’t come on .. hence my puzzlement. |
6th Sep 2021 3:18pm |
your not the one with head scratching switch problem
https://www.defender2.net/forum/topic64169.html |
6th Sep 2021 4:06pm |
I see mud switch or clones
I had them before with LED fitted a round the wrong way in side switch Last edited by dorsetsmith on 6th Sep 2021 5:28pm. Edited 1 time in total |
6th Sep 2021 4:27pm |
Oldsalt Member Since: 03 Jul 2018 Location: Hertfordshire Posts: 14 |
Had a similar problem recently adding a rear wash wipe switch. Just couldn't get the switch illumination to work UNTIL I remembered that LED light are precisely what they are called - DIODES and so need the connections the correct way for there to be light. The feed for each lamp needs to be going to the correct side of each lamp (if they are daisy chained it would only need one to be wrong to take them all out).
Sorry if stating the obvious but it confused me for quite a while. |
6th Sep 2021 4:30pm |
in light Old salt saying and two pints Sandford Devon mist recheck your wiring to dash illumination
and to your switches re Pos and ground Click image to enlarge if have ground and 12v + swooped between pin 8 and 7 |
6th Sep 2021 6:29pm |
lamp circuit code G/7 and circuit code 4 plus adding wire link pin 2 and 3 for uk spec
https://www.defender2.net/gallery/albums/u...819115.pdf |
6th Sep 2021 8:28pm |
Thats what I have mate .. all wired and working except the interior light ..
7th Sep 2021 6:32am |
Click image to enlarge Is this wire going to ground from pin 7 if not, it will let the switched led will work as it will ground thro dash lamp filaments with out dash lamps power but when power up the dash lamp no ground will be present at the switch for LED |
7th Sep 2021 6:52am |
Morning mate . Yes this is ground via neg on the light
7th Sep 2021 7:23am |
