![]() | Home > Off Topic > Domestic Telephone Sockets |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
If it’s just one wire in then yes you can just cut/remove the wire and that would have no effect, but make sure no bare wires are touching each other. Do you know where it is run from? Would be better to disconnect at the other end.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4232 ![]() ![]() ![]() |
I know where the maste4 socket is, would the extension come from there? 2007 110 TDCi Station Wagon XS
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3564 ![]() ![]() ![]() |
How many telephone sockets have you got? If this is the only one (other than your master Socket) then yes. It will.
yes wired daisy chin to all telephone sockets but not back master i.e. radial cct , but if you only have one extension from master to that one only |
Thanks all. We have the master socket plus 2 extension sockets. I’ll go and do some digging around the master socket to see if I can see the extension wire. I must also check if the extensions are even connected, they may not be, I’ve never used them. 2007 110 TDCi Station Wagon XS
