Home > Off Topic > Domestic Telephone Sockets
Bluest
Doing some decorating and want to remove a surplus telephone extension. It's not the master socket. The wire just dissapears into the wall. Does.anyone know, can I just cut the wire off , or will it knacker the the phone/broadband in the house.
 2007 110 TDCi Station Wagon XS
Post #920218 6th Sep 2021 10:58am
landy andy
If it’s just one wire in then yes you can just cut/remove the wire and that would have no effect, but make sure no bare wires are touching each other. Do you know where it is run from? Would be better to disconnect at the other end.
Post #920223 6th Sep 2021 11:47am
Bluest
I know where the maste4 socket is, would the extension come from there? 2007 110 TDCi Station Wagon XS
Post #920224 6th Sep 2021 11:52am
Rashers
How many telephone sockets have you got? If this is the only one (other than your master Socket) then yes. It will.
Post #920225 6th Sep 2021 12:05pm
dorsetsmith
yes wired daisy chin to all telephone sockets but not back master i.e. radial cct , but if you only have one extension from master to that one only
Post #920237 6th Sep 2021 1:16pm
Bluest
Thanks all. We have the master socket plus 2 extension sockets. I’ll go and do some digging around the master socket to see if I can see the extension wire. I must also check if the extensions are even connected, they may not be, I’ve never used them. 2007 110 TDCi Station Wagon XS
Post #920328 7th Sep 2021 8:39am
