Home > Wheels & Tyres > Tyre sizes that don’t rub on ET0 rims?
Gasket
Hi everyone.
I’ve been looking at some ET0 rims (torn between ANR classic and ET0 Wolf copies). Really like the stance with them and the improvement to turning circle would be nice too. I’ve already bought a set of genuine Wolf rims to replace my boosts, but planning to sell them to buy some ET0s.
But I’ve read on here that on factory suspension, at full articulation some tyres can rub on the arches when fitted with ET0 rims.
I much prefer the ANR classic rim, but being so wide - the tyre choice for me would be either 255/85/R16 (which do rub according to this thread: https://www.defender2.net/forum/post910500.html#910500) or 265/75R16s (standard NAS 90 fitment) which, although being 10mm wider than the 255/85/R16s are less tall at 803mm vs 841mm for the 255s.
…or ET0 Wolf copies, which would be my second choice - but, being narrower, would let me fit standard 235/85R16s.
Does anyone know if any of the above options would let me get away with my standard (just fitted, brand new genuine parts) suspension on my 2010 90SW and still avoid any contact with the wheel arch at full articulation/full load?
Post #919892 3rd Sep 2021 10:57pm
Co1
This might not be much help, but I’ve got ET0 rims with 235/85/16 tyres and get no rubbing. So that would work.
Post #919903 4th Sep 2021 6:34am
hank
285 75 16 did not rub when I had et0 Mach 5’s.
There are steering limit screws you can adjust to control rubbing > 110 XS Double Cab
Post #919907 4th Sep 2021 6:59am
kenzle8a
I’ve had 265 75 16 on wolf copies with no rubbing and 235 85 16 on et0 modulars with no issues.
Post #919910 4th Sep 2021 7:11am
Gasket
Thank you very much guys.
Sounds very promising! The rubbing I’m meaning is the rear arch under full articulation (rather than the front, which could be controlled by altering the lock stops).
These pictures from jimbo55 in the thread linked above illustrates it well (actually showing jimbo’s 90 on standard boosts with 255s):
https://www.defender2.net/gallery/albums/u...2D672.jpeg
https://www.defender2.net/gallery/albums/u...05043.jpeg
If I can get away with 265/75s on ET0 ANR classic rims without similar interference with the rear arch spat then I’ll definitely order a set. It’s quite a lot of money to save-up to buy the rims and tyres so it’d be heartbreaking if I found they caused a rubbing issue.
My brain is struggling to decide if, for a given tyre width/diameter, whether a reduced offset (so tyres sticking out more) would reduce or increase the risk of the treads catching on the rear arch spat.
I’m starting to think that it’s actually the extra diameter of the 255/85 tyres that causes the issue, rather than tyre width or wheel offset.
Post #919936 4th Sep 2021 1:29pm
Gasket
That does help co1 - thank you. At least my backup plan of ET0 wolf copies and standard tyres will work.
Just hoping that 265/75/16s on ANR classics will work too as they are a particularly lovely looking rim.
Post #919937 4th Sep 2021 1:34pm
JOW240725
I run 235x85r16 on et0 Wolfs and 255x85R16 on et0 ANR'S. I don't do serious off-roading but had no issues with either.
The only minor rubbing I've had is on the ANR'S when heavily loaded around corners, but think that's more to do with a saggy old suspension.
Both great rims. Thumbs Up James
Instagram @suffolk_rovers
Post #919945 4th Sep 2021 2:21pm
trailbear
I have the wolf copies with 265 / 75’s and am more than happy with them but again I don’t do mental off-roading so couldn’t really comment on that.
Post #919947 4th Sep 2021 2:27pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
ANR Classics with 265×75×16 KO2s on Standard Defender 90 loaded with a 300kg concrete block. No rubbing but don't do offroading. Not permitted in my country. Confused
Post #919949 4th Sep 2021 2:45pm
Gasket
Wow - you have both the options I'm looking at. must be a nice garage!
It's just dawned on me that the 265/75s on ET0 would likely be too wide and would protrude out from the wheelarch.
So 255/85/r16 on ANR classics would look absolutely sublime with a pleasant increase in height without affecting driveline angle - but may catch the rear arch (though, thinking about it, I do have disco isolators on the back springs now gaining a few mm) though wouldn't be an issue in all situations except for twisty axles...
Or 235/85/R16s on ET0 wolfs which will definitely fit but not quite as classic looking.
Some thinking time is needed I feel - damn these LR compromises, if only Nak had offered the ANR classics in a 7"j Laughing
Post #919951 4th Sep 2021 2:45pm
chek
Forgot to attach photo.
Post #919952 4th Sep 2021 2:46pm
Gasket
Chek - wow: they look fantastic!
Do the tyres protrude past the arches? (I mean do the plastic wheel arch eyebrows cover the width of the tyre?)
Post #919954 4th Sep 2021 2:48pm
JOW240725
I think you'll be fine with 265/75r16 on ET0. Personally, think 255 is a great size, but limited tyre choice.
Not the best photos, just what I have on my phone.
 James
Post #919981 4th Sep 2021 5:11pm
jst
same here. ET0s on front of my 130 Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #919989 4th Sep 2021 5:42pm
chek
Thanks! No, they don't protrude, they're legal.
Post #919997 4th Sep 2021 6:39pm
