Home > Maintenance & Modifications > How have you fitted your cubby...?? |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
on the original cubby there is a wooden spacer under the box which raises it up over the rear flange
see the dark one here - its about on inch and I think that the bolts go though it into the base plate .. Click image to enlarge Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
29th Aug 2021 12:26pm |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 298 |
Thanks for those pics, Ive 1st fitted mine and rested it on the back raised profile so its pretty much level. Going to swap the bolts over ridiculously too long.
29th Aug 2021 6:01pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8136 |
There are two wooden wedges that fit under to raise cubby height and make it level. One bolt in each corner is norm. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Aug 2021 6:43pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2948 |
Mine has 4 round puck like spacers
29th Aug 2021 8:03pm |
