Home > Maintenance & Modifications > How have you fitted your cubby...??
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
So since there's a few variations of cubby now Im checking how people have fitted there's, I understand its just 4 bolts either all 4 through the front part (under the drinks holder) or 4 in each corner.
Mines proving a sod as its too long to fit in between the 2 raised profiles the front before the gear stick and the rear where the bulk head meets the seating area.
Should it be fitted with one end resting on the raised profile?
Post #919082 29th Aug 2021 11:16am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
on the original cubby there is a wooden spacer under the box which raises it up over the rear flange
see the dark one here -
its about on inch and I think that the bolts go though it into the base plate ..
 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #919085 29th Aug 2021 12:26pm
karlp606
Thanks for those pics, Ive 1st fitted mine and rested it on the back raised profile so its pretty much level. Going to swap the bolts over ridiculously too long.
Post #919120 29th Aug 2021 6:01pm
jst
There are two wooden wedges that fit under to raise cubby height and make it level. One bolt in each corner is norm. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #919125 29th Aug 2021 6:43pm
ibexman
Mine has 4 round puck like spacers
Post #919135 29th Aug 2021 8:03pm
