![]() | Home > General & Technical (L663) > Wheel chocks recommendations |
Telemarkskier Member Since: 20 Jul 2020 Location: Wiltshire Posts: 129 ![]() ![]() |
As JRL no longer include wheel chocks with the Defender, I am considering https://www.amazon.co.uk/HOMCOM-Rubber-Veh...mp;sr=8-25
However if you have recommendations for me other than a house brick please pass them on. 2020 Defender 110 SE 240D: Fuji White. 2011 Freelander 2 SD4 HSE 2007 Freelander2 HSE (man) |
P50WKB Member Since: 05 Jul 2021 Location: Aberdeenshire Posts: 23 ![]() ![]() ![]() |
Snap ! - I do exactly the same.......with the added refinement of planing off the corners so that my lovely assistant doesn't get splinters (and before you say it, I only carry one pair of gloves)
You can't beat a good bit of lumber for packing, cribbing, supporting or shoring up.
I visited the new aircraft carrier, Prince of Wales, in Liverpool last year. It was reassuring to see that alongside all the latest and expensive gadgets they had purchased, the rapid response rescue and repair teams still carried bags of assorted timber blocks and various lengths wood. Some old things just can't be bettered. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
You never know in the middle if the ocean when you might need to make a cement box to stop the water coming in……… even on a modern, state of the art warship. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Mcrevilll Member Since: 09 Jan 2025 Location: NY Posts: 2 ![]() ![]() ![]() |
I see it’s been a while since you posted, but I’m curious—did changing the MAF sensor end up solving your issue for good? I’ve been having something similar and wondered if a new sensor made a noticeable long-term difference, or if you had to look elsewhere. Would be great to hear if anything else cropped up after the fix.
