![]() | Home > Puma (Tdci) > Intermittent starting problem |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
ignition switch is where i would start. its on the end of the ignition barrel that the key goes in. Roaming around 🇳🇴🇨🇭
Yep, ignition switch. Darren
ewinter110 Member Since: 19 Oct 2017 Location: Sesto Calende Posts: 5 ![]() ![]() |
Given the ignition switch a good clean up with contact cleaner and made sure there aren’t any loose connections there. Time will tell if it was just a bad connection.
