Home > Puma (Tdci) > VCV re learn |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Mine ran ok right from the first start, but it should learn itself over period of time. I’d take it out for a reasonable length drive, see if it improves. 2007 110 TDCi Station Wagon XS
13th Aug 2021 6:34pm |
Keswickgreen Member Since: 13 Aug 2021 Location: Norwich Posts: 3 |
Thanks Bluest, I did try this but it was dropping revs and cutting out so wasn’t confident of driving it down the road.
13th Aug 2021 6:43pm |
There must be someone on the forum with Nanocom or similar nearby that could plug in and force the learn for you. 2007 110 TDCi Station Wagon XS
13th Aug 2021 7:02pm |
Problem solved!! The new bolts that come with the VCV (Brit part) were too long. Put the old ones back in tightened up correctly and bingo all working fine.
17th Aug 2021 3:49pm |
One for the Britpart thread. Glad you got it sorted. 2007 110 TDCi Station Wagon XS
17th Aug 2021 4:34pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
What is it with those bolts, mine were too long too. Glad it's sorted. The first time I fitted mine it took a couple of hours but I fitted it upside down. Second time it took about half an hour but the bolts were too long. Third time it took about 10 minutes. 😀
17th Aug 2021 4:37pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Mine on my Denso genuine part were also longer, fortunately (because I dropped one) I found out before fitting.
I tried mine before and after the re-learn and did not detect a difference. The new VCV however made a massive improvement to throttle hesitation Mine was on 51k miles (2.4 from 2011) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
18th Aug 2021 12:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
I had the longer bolts issue too, just fitted and sorted.
Been running nice ever since and much much more power and torque $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Aug 2021 3:50pm |
