Home > Puma (Tdci) > VCV re learn
Keswickgreen
2008 Defender 90 Puma 2.4 HT Keswick Green
VCV re learn
Hi
Just swapped out a VCV on my puma 2.4 but haven’t completed the re learn. It’s not running correctly but having read some previous threads most people don’t bother to do this. Am I unlucky and will need to get this done or will it re learn over time?
Any help appreciated
Post #916784 13th Aug 2021 7:23pm
Bluest
Mine ran ok right from the first start, but it should learn itself over period of time. I’d take it out for a reasonable length drive, see if it improves. 2007 110 TDCi Station Wagon XS
Post #916789 13th Aug 2021 7:34pm
Keswickgreen
Thanks Bluest, I did try this but it was dropping revs and cutting out so wasn’t confident of driving it down the road.
Post #916793 13th Aug 2021 7:43pm
Bluest
There must be someone on the forum with Nanocom or similar nearby that could plug in and force the learn for you. 2007 110 TDCi Station Wagon XS
Post #916798 13th Aug 2021 8:02pm
Keswickgreen
Problem solved!! The new bolts that come with the VCV (Brit part) were too long. Put the old ones back in tightened up correctly and bingo all working fine.
Post #917428 17th Aug 2021 4:49pm
Bluest
One for the Britpart thread. Glad you got it sorted. 2007 110 TDCi Station Wagon XS
Post #917437 17th Aug 2021 5:34pm
AndyS
What is it with those bolts, mine were too long too. Glad it's sorted. The first time I fitted mine it took a couple of hours but I fitted it upside down. Second time it took about half an hour but the bolts were too long. Third time it took about 10 minutes. 😀
Post #917438 17th Aug 2021 5:37pm
MartinK
Mine on my Denso genuine part were also longer, fortunately (because I dropped one) I found out before fitting.
I tried mine before and after the re-learn and did not detect a difference. The new VCV however made a massive improvement to throttle hesitation Thumbs Up Mine was on 51k miles (2.4 from 2011) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #917538 18th Aug 2021 1:28pm
I had the longer bolts issue too, just fitted and sorted.
Been running nice ever since and much much more power and torque NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #917565 18th Aug 2021 4:50pm
