![]() | Home > Maintenance & Modifications > Repair shop wanted in Zaragoza Spain |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
We’re on holdiday and it’s becomes a tradition that something is wrong with the car.
![]() Therefore we are looking for a repair shop in the neighborhood of zaragoza. We are actually in Caspe which is 130 km from zaragoza. Kind regards Jack and the family Ps it’s a whistling sound in the neighborhood of the turbo but I can’t find any soot. a defender from 1984 pretending to be a puma with a touch of Range Rover |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Can't help directly but may be worth a pm to ALBERTDEFENDER he's based in Girona and may know someone.
Good luck ![]() His videos taken around Catalonia are worth a look. Just because you're offended doesn't mean you're right. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Have you split an intercooler hose? 1999 Defender TD5 110
Can check that tomorrow. Didn’t think of that. Looked at the turbo inlet hose today. But that was fine. a defender from 1984 pretending to be a puma with a touch of Range Rover
Of course. It’s standard equipment in the car 👍.
The noise is only when there’s no or very little load. a defender from 1984 pretending to be a puma with a touch of Range Rover |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
could it be always but not heard with the engine noise??
can you hear it at idle? I would think it could be a hose before or after the turbo, that is loose or split, or it could also be a accessory belt pulley Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
![]() Click image to enlarge In the end the car just stopped before finding a problem. Don't know if it is related or a new problem. The car is still being repatriated to the Netherlands (second time in 3 years). a defender from 1984 pretending to be a puma with a touch of Range Rover |
