Home > Puma (Tdci) > Air in fuel at a quarter of a tank… fine otherwise! |
fuel tank air vent
13th Aug 2021 11:13am |
Fin2020 Member Since: 13 Aug 2021 Location: Central Bedfordshire Posts: 2 |
The fuel tank breather pipe that runs back up to the “fill up” pipe? Replaced it when I dropped the tank because it had completely perished… still having the problem though, and would that cause air in the fuel line?
13th Aug 2021 12:55pm |
ok I had one pulling small vacuum on the tank and air being pull in from bad fuel line fitting ( the o ring seal in side fitting had naked )
13th Aug 2021 2:03pm |
13th Aug 2021 2:26pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
It took me weeks to find the culprit of air being introduced to the fuel, turned out to be a split filter housing.
When hotter fuel is returned to the filter housing it causes the split to open, allowing air in. Unrelated to how much fuel is in the tank, but worth noting |
13th Aug 2021 9:32pm |
