Home > Maintenance & Modifications > Galvanised Door Frames |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 489 |
Just fit Puma doors job done
10th Aug 2021 10:32am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
SP4x4 previously offered both skin options, but presumably the aluminium skins were less popular so have been dropped. I got the zintec version a few years ago and remain very happy with them. How much weight are you expecting to save by not having the zintec skins? I'd be surprised if it's more than a few lbs. Click image to enlarge |
10th Aug 2021 11:50am |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 151 |
Yes, Duralac is a for keeping corrosion out of joints. Used it on all sub and main assemblies back in the day, regardless of whether they were similar or dissimilar metals. Still use it now too. Click image to enlarge Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
10th Aug 2021 2:56pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
On a historical note Series One doors from the 54 model year to the end of production in 1958 had the Birmabright skin on a galvanised steel door frame with no sealant between the Birmabright skin and the frame. You never see any corrosion of the Birmabright on these doors.
10th Aug 2021 4:01pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
I restore Series land rovers and try to preserve original paint where I can.
To this end, I've previously bought bare steel door top frames from SP4x4, galvanised them myself and fitted the original skins back on. |
10th Aug 2021 4:30pm |
Birmabright is a lot more resilient than the regular aluminium used on later models and doesn't corrode in the same way. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Aug 2021 8:41pm |
^^^ Didn’t Series 2 from 1958 and later 2A have Birmabright door skins? I had a Series 2 many years ago where the door skins had corroded at the bottom.
11th Aug 2021 6:25am |
Birmabright was used up to the early eighties when the company went out of business. It wasn't corrosion proof but was much better than what came later. Darren
11th Aug 2021 8:03am |
