Home > Maintenance & Modifications > Loss of drive, clutch replacement
Stebo
Northern Ireland 2011 Defender 110 Puma 2.4 XS CSW Galway Green
Hopefully you guys can help me here.
I've a 2.4 Pump and I lost all drive from the clutch. The clutch pedal goes to the floor with no resistance and only the clutch-spring pushing the pedal back up. Can change through all gears but obviously pointless as clutch won't engage.
I'm not sure what the problem actually is, but I'm planning on no-nonsense approach and therefore have ordered up the following:
https://lofclutches.com/shop/clutches/clut...cba1185463
and
Hopefully this will fix whatever the problem might be, and future-proof the clutch for years to come.
Is there anything else that I am missing though? Anything else I should consider changing when the gearbox is that stripped? Also I take it that I will need new gearbox and transfer box oil - what's the recommended oils for these, and where's best to find out how much do I need?
All help / advice appreciated.
Thanks
Post #916398 10th Aug 2021 6:27pm
LR90XS2011
Looks like you have it covered, note some people experience transmission rattle with uprated clutches , I do and its very annoying DEFENDER 90 TDCI XS,
Post #916404 10th Aug 2021 7:15pm
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I've got a rattle, when idling in neutral, since replacing the clutch with an LOF unit. It certainly wasn't there before. As you say, very annoying. To the point where I'm half minded to strip the transmission again to try to resolve it.
Post #916408 10th Aug 2021 7:44pm
LR90XS2011
had my idle adjusted to 900rpm which helped but now it sometimes rattles and sometimes dosnt, I will replace the clutch again as soon as I have an excuse. DEFENDER 90 TDCI XS,
Post #916409 10th Aug 2021 7:46pm
Stebo
This does concern me a bit, especially with the LOF "extreme spec" clutch.
It's over-kill for anything I need, but I figured better safe that sorry.
If anybody is currently running the LOF Extreme spec clutch I would love to hear their thoughts.
Post #916425 10th Aug 2021 9:04pm
Stebo
Just to conclude the thread, I got my extreme spec clutch fitted (along with extreme spec one piece output shaft) and everything is spot on. No rattles and similar weight to the OE clutch.
More than happy with it.
Post #920003 4th Sep 2021 7:18pm
keef9t
Does anyone know what is rattling after fitting a replacement clutch. Is it confined to LOF units. Only hear it in neutral and it's not there every time.
Post #920017 4th Sep 2021 8:47pm
There's a good explanation of the cause of this rattle from Blackwolf here, which can be exaggerated by uprated clutches:
https://www.defender2.net/forum/post886106.html#886106 Darren
Post #920024 4th Sep 2021 9:22pm
90 Dreamer
What actual fault did you find on dismantling??
Post #920057 5th Sep 2021 8:04am
Stebo
Clutch was literally in bits. Seemed to just collapse / disintegrate. I'll try and get a photo of the old one.
I spent a fortune on other associated bits, which feels a bit like a waste when just a new clutch would have done, but at least I know that everything is tip-top now.
It also drives a lot better now - bit less slack in everything and nice clean notchy gear changes.
Post #920088 5th Sep 2021 11:20am
