Home > Maintenance & Modifications > Wing top chequer: to use gasket or not!
Co1
The foam gaskets supplied with my mammouth wing top plates is a rubbish fit, and frankly looks crap. What the general consensus about using gasket material? I figure the wing top will be scrap anyhow if I take the plates off due to the holes in it?
Was thinking about a thin bead of hylosil or tiger sealant to seal it around the edges.
Col
Post #915807 6th Aug 2021 3:55pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Use them, or get some 2mm closed cell foam and make your own Thumbs Up
Post #915810 6th Aug 2021 4:44pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Tiger seal would work - or what about 1 or 2mm neoprene/rubber and use the plate as a pattern? Rgds.
Chris
Post #915818 6th Aug 2021 5:36pm
Co1
Cheers. I’ll have a go at trimming back the gasket it has come with. It’s not close cell foam, it sort of a medium cell foam! Will see how it holds up, but it doesn’t exactly cut neatly. Time will tell!
Post #915819 6th Aug 2021 5:38pm
Go for 2mm closed cell adhesive foam in black or whichever colour.
Clean the underside of the CP well, rubbing alcohol is ideal.
Adhere it to the CP and then cut off excess around the edges. A scalpel and a cutting mat is ideal although a little more tricky if the CP is coated or painted. You could use some 3M 3434 blue tape to protect the edges.
I’m not sure what mine has under it as I didn’t fit it, I think nothing but couldn’t guarantee it but it’s staying where it is so doesn’t worry me.
You could cut the excess off a few mm in from the edge from the underside did you wanted to as well but you will blunt your blade tips and ideally need a tape for a cutting guide.
As it’s hidden you’d never notice but you may get the edge contact the paintwork though instead. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #915823 6th Aug 2021 6:23pm
Co1
I’ve trimmed it up about 2mm short on all end he and it fits quite well now. The only thing is that the CP is black and the gasket is light grey. If it looks crap I’ll take it off and order some black closed cell foam.
Post #915824 6th Aug 2021 6:30pm
Siwynne
I’ve just had my cp powder coated and needed new gasket. I used this stuff.
https://www.ebay.co.uk/itm/1m-x-1m-3mm-Clo...635-2958-0
It’s mega sticky but worked a treat.
Post #915836 6th Aug 2021 7:25pm
Yep, that’s the stuff.
I used it as a backing for various interior electrical bits I installed as well.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #915838 6th Aug 2021 7:35pm
