Home > Puma (Tdci) > Oil leak Puma D90 2009 in the muffler pipe, Is this normal? |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
I presume by muffler pipe you mean exhaust. If that is the case are you sure it is oil and not condensed water mixed with exhaust soot/carbon caused by the initial cold exhaust condensing out some water on start-up? If that is the case then I would say that was normal. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
27th Sep 2011 3:09pm |
MaxD90 Member Since: 26 Sep 2011 Location: Dominican Republic Posts: 12 |
You are right: Exhaust. I`m not sure if it its water mixed or oil. Here is a pic. What do you think? Thanks!!! |
27th Sep 2011 3:46pm |
Hi MaxD90,
That looks like water and soot condensate. Nothing to worry about. If you get LOTS of steam or dirty water coming out of the exhaust WHENEVER the engine is running then ? head gasket - but I would suggest what you see in that picture is Normal, especially if you don't get it after the engine and exhaust are warmed up. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
27th Sep 2011 4:03pm |
THANK YOU, THANK YOU, THANK YOU!!!!!!!!!!! I feel so relief with your opinion!!!! Now I think I could sleep at night!!! Take care |
27th Sep 2011 4:31pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Catch some in a glass jar and put it in your garage. After a day or two it'll seperate if it's water / soot to clear water on the top.
27th Sep 2011 4:47pm |
You're welcome. LANDYWATCH
27th Sep 2011 6:02pm |
Thanks man |
29th Sep 2011 11:09am |
