Home > Maintenance & Modifications > SEED NETS RADIATOR PROTECTION
JEFF DEFENDER 90
United Kingdom 1989 Defender 90 300 Tdi PU Bonatti Grey
ARE SEED NETS WORTH FITTING TO CROSS AFRICA
Post #915603 5th Aug 2021 11:00am
camelman
Only really if you are out in the bush ploughing through deep grass.
Otherwise you're just restricting airflow to the radiator.
Post #915604 5th Aug 2021 11:05am
JEFF DEFENDER 90
thanks for the Answer, i fould a guy who fitted one and crossed the Kalahari Desert with one fitted 2000 miles and had no heat problems and it was 44 degress, so i dont think heat will be a issue, so i think thats a road test and a half ??
Post #915605 5th Aug 2021 11:25am
camelman
I spent a lot of time in the Kalahari, Namib and the Okavango as part of a Cape Town to Nordkapp trip. I'd fit the seed nets when needed otherwise they're just collecting bugs.
Post #915613 5th Aug 2021 11:58am
JEFF DEFENDER 90
thanks very much, i found a guy in Surrey that sells them,
Post #915615 5th Aug 2021 12:17pm
jddisco200tdi
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Here in Australia you do need a cover to the radiator for some of our deserts. Grass seeds are the main thing to stop.
Anything like shade cloth does restrict air flow. I use window flyscreen netting, and only install it when I get to the area it is required. Another thing to watch out for is grass collecting above bash plates. It can catch fire quite easily. Regards
John D - Defender 110 2.4
Post #915731 6th Aug 2021 7:17am
camelman
Post #915737 6th Aug 2021 7:47am
JEFF DEFENDER 90
Thanks, very useful infomation guys.
Post #915772 6th Aug 2021 12:35pm
