Home > Faults & Fixes (L663) > Floormat fastener broken
Defendit..
Netherlands
Removing my rubber floormats for cleaning yesterday and discovered that one fastener was broken / separated.
2 pcs. design, backpart is loose under the underfloor Lining.
Will visit dealer...
 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #915580 5th Aug 2021 8:51am
Kubrick1978
Let me know what happens - that surely shouldn't be happening! I'm always taking out my rubber mats to hose them down - hopefully this isn't a common problem.
Post #915673 5th Aug 2021 6:48pm
graemesmith1960
Just found this post. Search facility didn’t find it. I’ve got the same problem and it happened again after a replacement.
From my other post:
Has anyone else had the retaining studs for the foot mats come out of the floor? My drivers side mat pulled the stud apart the first time I tried to remove the mat leaving a hole in the floor with no way to reattach the stud. The dealer duly ordered a new clip and 2.5 hours of labour later it was fitted. Guess what? First time I remove the mat again the stud comes apart. This time I can just see the other bit of the stud under the floor and it looks a pretty poor design. Either it is supposed to be compressed by a ring which has broken again or else the hole in the floor is supposed to do the compression and the hole I have looks like it has been reamed out a bit so is pretty large.
I haven’t heard of any one else with this issue but if there is what was the solution? If my suspicions are correct I’ll need a new floor panel. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #951689 5th May 2022 5:16pm
Defendit..
Netherlands
Next time I will fix it myself, Just by using superglue. No Mud flaps for my 90.!
Post #951781 6th May 2022 11:32am
