Home > Technical > Defender 90 TD5 fuel pump
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
I have noticed that there are 2 Bearmach fuel pumps available for the Defender TD5 with one for the 90 and one for the 110.
What’s the difference? The 110 ones seem a little cheaper but look exactly the same?
Jim
Post #915415 4th Aug 2021 8:59am
rallysteve
Different fuel float arm/level to account for the different tank shapes i believe.
Post #915424 4th Aug 2021 10:07am
jimbo55
As said above the tanks are different sized and shapes, I believe that you can swap the floats over though.
If you’re doing the job, make sure you get a genuine pump and not a cheap aftermarket one, it will save you doing the job multiple times.
Also worth getting a new locking ring as well as they are normally rusty and a pain to get off in one piece.
Post #915425 4th Aug 2021 10:20am
jim4244
I was going to go for a Bearmach pump. Are these not good?
Jim
Post #915428 4th Aug 2021 10:33am
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Lots of people suggest only using genuine pump.
Not sure exactly why but likely to be with quality and durability.
Had mine replaced 4 months ago with genuine Thumbs Up
Post #915464 4th Aug 2021 3:33pm
jimbo55
From experience the aftermarket ones are very noisy and don’t last very long, but a genuine Vdo siemens unit is probably 3 or 4 times the price of a Bearmach or britpart one
Post #915477 4th Aug 2021 4:20pm
Discovery ones used to be even cheaper than defender.... and you can just unclip the arm and swap over.
Post #915513 4th Aug 2021 8:03pm
