Home > Modifications & Maintenance (L663) > Does the NEW Defender has 2 batteries or place for a 2nd one
cyberhusky
Luxembourg
I was searching for the rescue blueprints for the latest Defender. These rescue sheets do help firefighters and rescue teams quickly find batteries, gastank etc.
What I find interesting is that there are 2 batteries shown on the Defender 110 model these sheet are made by LR and Modi Tech Rescue Solutions.
Are there 2 batteries built in or does Land Rover sell this as an option?
Recue sheets for other LR cars can be found here on the German site (didn't find the English versions)
https://www.landrover.de/ownership/emergency.html 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #903598 17th May 2021 4:43pm
Retroanaconda
12V battery under the drivers seat. MHEV have the 48V battery under the boot floor.
Post #903600 17th May 2021 4:58pm
Landy718
United States 2016 Defender 110 Other USW Auto Santorini Black
It's fairly easy to add an aux battery if that's what you're looking for. I'm in the process of building out an area where the 3rd row seats once lived.
(mild hybrid battery can be seen here directly in the middle of the image)
Post #903630 17th May 2021 7:53pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Could the second battery possibly be one for the stop/start system? I know when I had a later Discovery it had two batteries fitted, one for normal car duties and one for the stop/start system. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #903664 17th May 2021 11:22pm
Gareth
To be honest, I think the mild hybrid bit is just a posh stop/start system. It doesn’t seem to do anything else.
Has anyone actually measured the volts on the rear battery? Is it 48v? Or is there a transformer in the system to up the volts to the stater?
Problem is, there is no readily available technical info out there. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #903671 18th May 2021 6:59am
Retroanaconda
The MHEV system is a posh stop/start, with a belt integrated starter generator on the engine with is part of the 48v system.
All the info is in the workshop manual on Topix. The basics are in the user guide.
Post #903739 18th May 2021 1:57pm
Schurli
Austria
dual batterie setup / or use the 48V ?
Hi I am new in this forum but highly interrested in a upgrade on my Defender 110 (D200 /2021 MEHV). I want do use my refrigerator also If I am NOT driving... And it looks I can not use any Batteries installed by the factory. So I need to run 2 second (Beside Start and 48V MEHV) Or Is there a way to force the 48 V system to charge fully ....
Has anyone alredy done a dual battery set up?
Post #913156 19th Jul 2021 10:27pm
tino
South Africa
Good morning.
We have done several on the the D240, p400 and D300 in South Africa.
We have special supporting brackets for the P400 and on the 240/300
I will attach some pictures I hope
it helps.
Tino
Post #915255 3rd Aug 2021 7:11am
GreenMonster
United States
Why do you say that when the MHEV is specifically stated to power the super charger during acceleration. Isn’t that it’s main purpose?
Post #915572 5th Aug 2021 7:44am
Retroanaconda
On the I6 D200/D250/D300 engines the MHEV is just a posh stop/start, but yes on the P400 it has the electric supercharger.
P400s are quite rare over here as we (thankfully) get the diesel engine options.
Post #915660 5th Aug 2021 5:15pm
cyberhusky
Luxembourg
Expedition Parts do now have a dual battery installation as an option.
https://shop.expedition-parts.de/en/detail...egory/1325 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1015065 14th Nov 2023 11:16am
whiterdesign
The 48v battery is not just for start stop, with the belt driven starter/ generator, when accelerating it drives the starter motor to assist the engine and reduce the vehicle emissions. This is what a MHEV is all about. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #1015257 15th Nov 2023 8:53pm
