![]() | Home > Maintenance & Modifications > High pressure fuel supply eaten by animal! |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 537 ![]() ![]() |
They are the leak off pipes and return to tank. The high pressure ones are the metal pipes to the injectors. Leak off pipes are available for Tdi and the likes, not sure for the TDCi though others with more knowledge will answer better, I have only got up to TD5 era.
Your repair will be ok in the short term, but make sure they are diesel resistant. |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
I believe you can also get 'rodent tape' which deters them in the first place.
I've no experience of it myself but a friend who's bulkhead I'm replacing at the moment is going to buy some for parts of his wiring loom that the mice have been nibbling. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Time to replace the cat on the down pipe……
LR005749
Injection pump to manifold pipe JLR |
or install cat in fan shroud ![]() |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
A pity it only comes as an assembly instead of being able to replace single hose parts. I will order one though.
I looked into that rodent tape - it seems to not always be effective. thin paint laced with hot chilli pepper/powder looks to be quite popular and effective though! Thanks all. ![]() |
