Home > Td5 > transfer box
Page 2 of 2 <12
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
so do td5's run LT230's? the same as 200/300's? Or?
We'd prefer to use a good secondhand Disco unit, rather than an Ashcroft one to be honest, mainly down to cost (tight Northerners ya see Laughing )
Post #91449 26th Sep 2011 9:58pm
Yes, they all run the same kind of t/box, LT230. even the new puma defenders use a 1.2
The discovery box is an LT230Q... Quiet(er) gears apparently. Rolling Eyes in 1.2:1 flavour.
Td5 defenders are 1.4
Post #91451 26th Sep 2011 10:01pm
JSG
bpman wrote:
I did my transfer box on my td5, bought the kit from ashcroft, made the truck much much quieter and raised the gearing but not by much. the kit was about £300 and fitting cost over £600 so do the math before jumping in.
if you take the ashcroft one day swap, be aware they will give you a donor t-box because it takes time to do the rebuild... i could be corrected on this - anyone ?
Not sure that's correct - the TR90 went in for a new gearbox and I had the ratios done at the same time (£260ish extra) and they swapped the ratios out in my existing transfer box. John
2011 Tdci 110 CSW XS
Post #91494 27th Sep 2011 8:36am
ashtrans
Site Sponsor
sorry you are mistaken, if we do the ratio swap we chnage the gears in your unit, if you order a rebuilt unit then it's changed for another
Dave Dave
Post #91680 27th Sep 2011 9:25pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
i will be keeping an eye on this thred as this is something i would like to do
Post #92782 5th Oct 2011 2:36pm
buds
can i just ask will the disco 2 box fit with out any mods as some have said it will
really not sure which way yo go here
thanks
Post #93405 9th Oct 2011 3:19pm
T1G UP
overdrive? then you have the best of both worlds
Post #93415 9th Oct 2011 4:17pm
Page 2 of 2 <12
