Home > Td5 > transfer box
buds
transfer box
hi guys
just after some advice on transfer boxs i want to uprate mine for motorways etc as i dont want to get rid of my 90td5
can someone point me in the right direction of what one and where to get it from
thanks
Post #90882 23rd Sep 2011 4:00pm
markb110
Hi
Why not start by checking out Ashcroft Transmissions website. They also provide a fitting service. A mate of mine is looking to do this.
My 90 has the Discovery T box fitted by the previous owner. Worth doing.
CWS 4x4 in Glastonbury might be able to supply you a second hand unit if you can do it yourself
Good luck
Mark
Post #90885 23rd Sep 2011 4:37pm
Martin
Site Admin
So good he said it thrice!
I've just fitted a D2 box to my 90, a few things to bear in mind...
The D2 box didn't have a speedo transducer take off, so the rear housing had to be swapped between the boxes; also the front prop output flange is different so these too were swapped. Not a major hassle but not the straight swap that everyone else claims Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #90889 23rd Sep 2011 4:42pm
markb110
Thanks Martin
No idea what happened there Shocked
Post #90892 23rd Sep 2011 4:45pm
Yorkshire90
good route to go down. I bought a 2004 disco 2 box from ebay. Around 200 iirc then had it professionally fitted. Runs like a dream and has done for 3 years since its installation. Prefer it to the gkn overdrive I removed. Are you upgrading the power to cope with the box? Can be sluggish otherwise...
Post #90894 23rd Sep 2011 4:53pm
Martin
Site Admin
This "needs a remap to cope" is another myth, my untuned Td5 90, which is also on 265 tyres copes absolutely perfectly with the 1.222:1 transfer box.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #90896 23rd Sep 2011 4:59pm
I have one (a 1.2:1) on my 110. makes the world of difference.
Maybe not so noticable on a 90, but my lardy 110 (SW) needs a bit of ooomph to get it going on steep hillstarts, so i've had it remapped and it goes a lot better now.
If I fit my larger 255/85 tyres, then hillstarts can be a problem, although just slip it into low 2nd, get going and shift up into high range, no problem.
Post #90899 23rd Sep 2011 5:28pm
buds
thanks guys for that is there any year for the disco box i need to get
as for the power side it is chiped also a big intercooler and a decat pipe
Post #90910 23rd Sep 2011 5:48pm
JSG
I had Ashcroft swop the ratios on my TR90 - well worth doing. Thumbs Up John
2011 Tdci 110 CSW XS
Post #90931 23rd Sep 2011 6:22pm
Yorkshire90
It's not a case of it not coping. I agree that's a myth. But the truck is a bit of a slug and loses the acceleration bite from the standard box gearing. Transforms the vehicle when combined.
Post #90938 23rd Sep 2011 6:58pm
landy andy
Done the same to my Td5 90.
Is yours remapped?
I would advise a good second hand box, or a new one from Land Rover, as opposed to a rebuild or recon. Or you can have miserable time and spend plenty of money, even with the big names.
Pm for more info if you require. As not good to name names or experience.
Andy
Post #90945 23rd Sep 2011 7:34pm
Martin
Site Admin
Quote:
is a bit of a slug
Don't agree.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #90949 23rd Sep 2011 7:47pm
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
Sorry to take over the topic, but since I've done my transfer box swap in my tdi, my mate wants to do the same in his tuned td5. Will only t/boxes from Disco 2's fit?
Post #91419 26th Sep 2011 7:14pm
I did my transfer box on my td5, bought the kit from ashcroft, made the truck much much quieter and raised the gearing but not by much. the kit was about £300 and fitting cost over £600 so do the math before jumping in.
if you take the ashcroft one day swap, be aware they will give you a donor t-box because it takes time to do the rebuild... i could be corrected on this - anyone ?
Post #91445 26th Sep 2011 8:45pm
landy andy
I think any of the boxes fit. Most of the Disco 2 ones did not have CDL, so would be an early Disco 2 anyway.
You are correct BP, and that you will be given a box of unknown origin. If yours is good keep it.
Andy
Post #91446 26th Sep 2011 8:46pm
