Home > Puma (Tdci) > Leak into passenger footwell
RandomMan
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
Hello all, my 2007 Defender leaks when it raining and the car is outside the house (stationary). It pools in the passenger foot well....
Anyone been down the path of finding it?
Jon
Post #914271 27th Jul 2021 3:16pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Welcome to the joys of Defender ownership Laughing
You might find this of use https://www.defender2.net/gallery/albums/u...cedure.pdf
Short answer is it could be coming from one of a dozen places though 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #914279 27th Jul 2021 3:56pm
Smoeandco
Australia
I posted the same question to another forum 6 months ago during heavy rain. The old boys told me to get used to it as Fenders leak like sivs.
Can alternatively have a crack at rerouting the front gutter edge away from door trim towards windscreen with a weld or bolt on adjustment but I didnt think it was worth the trouble.
Post #914361 28th Jul 2021 4:35am
Mine suffered from this and I tracked it down to the joint between the heater box and the bulkhead. Water runs off the gutter across the rear of the bonnet, onto the wing and then into the engine bay directly above that joint. I did have a fender seal fitted and when the problem first appeared I realised that it had fallen off. I've since re-attached it with a bead of Sikaflex and all is good so far!
Here's the details of the seal, albeit being shown fitted to the drivers side. It's the same part for both sides:
https://www.defender2.net/forum/post840283.html#840283
The proper solution would be to remove and refit the heater box with a better seal but that's quite a significant task. Darren
Post #914391 28th Jul 2021 7:45am
Guinness
For me, after every rainfall i would get a leak in my passenger footwell. My windscreen seal was very cracked so when getting other work done to my defender i got it replaced. Since replacing the seal my defender doesnt resemble a swimming pool after rainfall!
Post #914425 28th Jul 2021 12:10pm
Oldowner
This is what they look like when the dash is removed after the screen seal has failed and not sorted.
This 08 Puma looked perfect until dash and soundproofing removed.
Post #914427 28th Jul 2021 12:15pm
BIMbound
I replaced a ripped / tatty watershedder behind the door card. Water was sitting on a 'ledge' of foam and trickling down the outside of it rather than being directed out of the bottom of the door.
Post #914591 29th Jul 2021 10:26am
Brimac
United Kingdom 2010 Defender 110 Puma 2.4 USW Aintree Green
i have made a mound out of stones on my drive to raise the rear wheels a bit, much better now when it rains
Post #918339 23rd Aug 2021 3:27pm
