Home > Maintenance & Modifications > Indicators not cancelling/cancelling at wrong time. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3686 |
Have you had the steering wheel off recently?
26th Jul 2021 5:03am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5755 |
Original steering wheel or aftermarket. Aftermarket ones use the sprung collar off the original wheel, or pins in the boss and need to be setup correctly.
26th Jul 2021 6:49am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 628 |
Make sure the arrow on the indicator unit is pointing towards the stalk when re-installing the steering wheel.
26th Jul 2021 7:56am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Same problem here with the original steering wheel. 03 plate. Defender 90 XS TD5 (03 Reg)
26th Jul 2021 8:51am |
Click image to enlarge Red arrow show indicator causal unit is pointing towards the stalk |
26th Jul 2021 10:07am |
Looks like mine should be fine then?
Unless the ring on the steering wheel itself is off? Click image to enlarge Click image to enlarge Defender 90 XS TD5 (03 Reg) |
26th Jul 2021 10:43am |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
I haven't but might have been off befre I bought it... it's an original wheel. will have a look as suggested. Cheers
26th Jul 2021 9:08pm |
