Home > Maintenance & Modifications > Indicators not cancelling/cancelling at wrong time.
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I seem to have an issue with my indicator stalk, where for example I indicate right, and as I wind lock on it cancels the indicator (I would expect this to happen as you wind lock off coming out of a corner)
I also find it often doesn't cancel as you wind lock off, meaning I go off down the road not hearing the quiet tick of the indicator relay.
Is this something that can be tampered with to get working correctly, or is it most likely worn out and could do with just replacing? (02 plate)
Post #914025 25th Jul 2021 8:28pm
Co1
Have you had the steering wheel off recently?
Post #914045 26th Jul 2021 5:03am
landy andy
Original steering wheel or aftermarket. Aftermarket ones use the sprung collar off the original wheel, or pins in the boss and need to be setup correctly.
Post #914048 26th Jul 2021 6:49am
Oldowner
Make sure the arrow on the indicator unit is pointing towards the stalk when re-installing the steering wheel.
Post #914052 26th Jul 2021 7:56am
Waldo
Same problem here with the original steering wheel. 03 plate. Defender 90 XS TD5 (03 Reg)
Post #914058 26th Jul 2021 8:51am
dorsetsmith
Red arrow show indicator causal unit is pointing towards the stalk
Post #914066 26th Jul 2021 10:07am
Waldo
Looks like mine should be fine then?
Unless the ring on the steering wheel itself is off?
Post #914069 26th Jul 2021 10:43am
balmybaldwin
I haven't but might have been off befre I bought it... it's an original wheel. will have a look as suggested. Cheers
Post #914176 26th Jul 2021 9:08pm
