Home > Wheels & Tyres > Sawtooths, wranglers and spacers?
souster4
Hi guys
Has anyone got the OE sawtooths with goodyear wrangler MTR's (235/85) and then 30mm spacers that they would be willing to share pictures of?
Really keen to see what this set up looks like, anyone help please?
Cheers all
Post #913861 24th Jul 2021 11:09am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
I don’t have a picture, bit I have a friend with this setup on a 90 and it looks a bit goofy in my opinion.
The MTRs aren’t a wide tire, and the Sawtooths are et20. So far, so good
Add a 30mm spacer and you’re at et-10 and a narrow tire pretty far out… Roaming around 🇳🇴🇨🇭
Post #913879 24th Jul 2021 4:03pm
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I too have the factory wranglers. And I was also considering 30mm spacers, partly for looks and partly for turning circle improvement. I’d also like to see what it looks like before I do it.
I’ve seen wider tires with spacers looking good, but not the original 235s.
Post #914579 29th Jul 2021 10:13am
JOW240725
The best I can offer is 235x85R16 boosts with conti's before and after adding 30mm spacers. I believe are the same as Sawtooths? It'll look great and improve your turning circle (when you adjust the steering stops correctly).
 James
Instagram @suffolk_rovers
Post #914602 29th Jul 2021 12:24pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Not sawtooth’s or MTR’s but same tyre size & 30mm spacers fitted - an improvement in my view.
Post #914603 29th Jul 2021 12:56pm
pilsburypie
I like. Thanks for the photos. I agree, an improvement but subtle.
I always thought my wheels sit well inside the arches. Could do with an inch or so to fill them out. Might get some now.
Having not had my defender long and moving from a “normal” car, I’ve been caught out a few times with the terrible turning circle Laughing hopefully this aesthetic improvement will have practical benefits too.
Post #914605 29th Jul 2021 1:05pm
Co1
Here you go.
Post #914613 29th Jul 2021 2:21pm
pilsburypie
Again, fill out the arches nicely in my opinion.
Post #914661 29th Jul 2021 8:22pm
90 Dreamer
SVX wheels / 235 tyres & 25mm spacers
Now Blindo's with 265x17" tyres
Post #914664 29th Jul 2021 8:44pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
You do know just changing the wheels/tyres/spacers won't improve the turning circle, don't you?
The key issue is adjusting the lock stops so the wheels get as close as possible (or even slightly touching) the radius arms at full lock. LR seem to ship vehicles with a very conservative adjustment and a big improvement can usually be had just by optimising the standard set-up without changing the wheels or fitting spacers.
Post #914688 29th Jul 2021 11:57pm
pilsburypie
Thanks for the info. I shall look into that.
Post #915015 1st Aug 2021 4:31pm
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
235/85 with 30mm spacers
Post #916038 8th Aug 2021 12:30pm
