Home > Td5 > Steering wobble |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 |
The mating faces are all clean.
My next step will be the preload. Instagram - @Land_Rover_Defender |
19th Jul 2021 10:27am |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 |
Steering damper is a red herring - it’s not there to damp that sort of high frequency wobble, its purpose is to damp steering kickback from ruts etc. - if it does anything to prevent it, it’s only masking the real problem.
If you’ve done all the bushes and the wheels are properly balanced, swivel pin pre-load would be what I’d check (I had the opposite - turned out to be Panhard bushes, wear wasn’t obvious until they were out). |
19th Jul 2021 11:00am |
Had all my wheels balanced about a month ago now, so I am confident this isn't the issue. But yes I have heard stories of people going through everything and then swapping wheels over to then cure the wobble. Instagram - @Land_Rover_Defender |
19th Jul 2021 1:16pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
I did the same. Even tried another garage just in case...still the same. Swapped around and all good. 1999 Defender TD5 110
19th Jul 2021 1:19pm |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
When I first bought mine it had brand new tyres and wheel wobble at around 60mph, took it back and asked them to check wheel / tyre balance.
Took it home, the issue wasn’t cured. Took it back, they took it somewhere else to check wheel balancing, and this time round they sorted it. So it sounds like not everyone can balance them bob on first time. Edited: mine’s a Puma sorry, although not sure that makes a difference. |
19th Jul 2021 2:20pm |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
when i had a death wobble at 45mph, it was the panhard rod (would add it was as bad as a bike tank slapper, and scared me witless)
once replaced i was left with a steering wheel wobble which was a wheel bearing incorrectly set up moving back to 235's on standard rims from 285's on offset rims also lightened the steering, and i would not go back to oversized tyres now good luck 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
19th Jul 2021 3:46pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2652 |
That’s why I use AJS Tyres (Andy used to be a site sponsor) in Reigate as they can deal with the larger tyres.. |
19th Jul 2021 4:05pm |
Reduced the number of shims on the top pin of the swivels today and it has fixed my wheel wobble!
They weren't loose but clearly not tight enough to prevent wobble. Can finally enjoy driving it again with the new Superpro bushes and having it setup properly. Thanks for the suggestions. Greeny. Instagram - @Land_Rover_Defender |
23rd Jul 2021 9:18pm |
