Home > Td5 > Steering wobble
Greeny
Steering wobble
Had fairly bad steering/car wobble when going 60mph.
Got my wheels balanced and have since fitted superpro bushes all round, but still have the wobble. It isn't consistent, sometimes I have 0 wobble at 60mph, other times it is fairly bad.
Any ideas on what to check next? I recently replaced the swivels so I don't think it is them, but might take a shim out either side and see. I can feel the vibrations through the seat and wheel.
Cheers Greeny. Instagram - @Land_Rover_Defender
Post #912869 18th Jul 2021 8:15am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
How old are your shocks and steering damper? Roaming around 🇳🇴🇨🇭
Post #912871 18th Jul 2021 8:42am
If you've recently replaced the swivels then it's almost certainly an incorrectly set preload on them. Removing a shim may well cure it but you really need to measure with a spring balance to set them properly. Darren
Post #912872 18th Jul 2021 8:44am
htb2
Wales
Remember swivel preload on a defender axle higher than a disco/R.rover axle as one twin bearings other bush/bearing
Post #912891 18th Jul 2021 9:56am
Greeny
Shocks and steering damper are the two things I havent replaced underneath. New bushes and new springs. Instagram - @Land_Rover_Defender
Post #912894 18th Jul 2021 10:01am
Greeny
When I did the swivels I measured the preload with a spring balance, so they should be correct... I am hoping.
There isn't any play in the pin bearings or wheel bearings. Instagram - @Land_Rover_Defender
Post #912895 18th Jul 2021 10:03am
htb2
Wales
I replaced my swivels and had to redo swivel preload about a month or two later as they had loosened, typical britpart, should have used timken bearings instead. Mind and remove oil seal to get preload.
Post #912899 18th Jul 2021 10:26am
excossack
Move front wheels to the rear and rears to the front and see if the wobble goes. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #913000 19th Jul 2021 7:07am
kenzle8a
I get a non specific steering wobble too on my TD5 sometimes, all the bushes are brand new, I've checked the bearings for play and can't find any but mine is just through the steering wheel and doesn't always present in the same way. I've got a new Panhard rod and drop arm to go on and the other thing on my list is a new lower steering column as it could be the UJ's in there.
Post #913001 19th Jul 2021 7:11am
jimbo55
Steering damper and swivel preload are the most likely causes, if you’re running larger tyres it’s definitely worth considering upping the preload from the standard values. If you have replaced them recently then do check them as they do bed in and lose the preload.
There are loads of other possibilities though, for example I currently have intermittent wobble and it’s being caused by the transfer box output shaft having play in it
Post #913005 19th Jul 2021 7:22am
markb110
Don’t forget the ball joints on the front anti roll bar.
If there is any grease left it’s probably gone hard and the ball notchy.
My money is on the panhard rod.
Change one thing at a time then test, otherwise you won’t know what the culprit was for next time.
Post #913008 19th Jul 2021 7:26am
Greeny
Every bush underneath has been changed for a superpro one, including panhard rod bushes, old one pictured above. All new anti roll bar joints front and rear and superpro bushes.
I am running 285/60s which are a big tyre and the steering does sometimes feel light over country lanes. Maybe I do need to adjust the preload to suit the tyres more.
UJs are also new and have 0 play in them.
The only that hasn't been changed are the shocks and steering damper. What's left to check would be the preload and then maybe steering arm? Not sure what else to look at now. Instagram - @Land_Rover_Defender
Post #913020 19th Jul 2021 8:50am
rallysteve
Have you got wheel spacers on? 02' 110 TD5 Double Cab Rebuild Thread
Post #913029 19th Jul 2021 9:26am
Greeny
Rally Steve, not running wheels spacers no. Just the 285s with a ET 10 offset, so they on the limit of the arches.
Bearings etc got done when I replaced the swivels a few months ago, so they are all tight. Instagram - @Land_Rover_Defender
Post #913032 19th Jul 2021 9:30am
rallysteve
Are the mating faces on the hubs/wheels clean? This can often be an overlooked cause of wheel wobble and can affect front and rear axles but most pronounced via the steering wheel on the front axle of course.
Cheers,
Post #913036 19th Jul 2021 9:57am
