Home > Td5 > Headlights not working |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6113 |
The dim-dip box is mounted behind the dash binnacle; looks like a large relay, it's a maroon colour.
you can get a bypass unit for it (i've got one in the bulkhead i'm building up, can get you the part number tomorrow if needed), which is just a "relay" box, with a wire link in it, across the main switch contacts (to keep power to the headlights whenever the stalk off/sidelight/main switch is switched on. |
25th Sep 2011 8:18pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
Thanks Jamie,
The part number would be useful. Think I have a spare main beam stalk around somewhere, so may change that to test. Can't think what else it could be. Andy |
25th Sep 2011 8:39pm |
