Home > Maintenance & Modifications > Ultragauge installation |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Personally, I would not cut it - the cover is quite easy to remove.
You can also remove the obdii port from its bracket and kind of push it back in the dash with the untragauge plugged in, then close the cover Roaming around 🇳🇴🇨🇭 |
16th Jul 2021 3:06pm |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Thanks I’ll take another look at it and yep the cover comes off ok so was just speaking of refitting it with the gauge plugged in.
16th Jul 2021 3:10pm |
Marvellous thanks again and all done. The fuse box cover lives to fight another day…..
16th Jul 2021 3:31pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Just buy a 90 degree OBD extension cable - allows the fuse box lid to clip back as normal. Rgds.
Chris |
16th Jul 2021 5:12pm |
Thanks I have since looked at those too.
16th Jul 2021 5:23pm |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 |
Very useful as I was just looking at how best to fit mine without damaging the fuse box cover.
Thanks! |
16th Jul 2021 7:46pm |
