Home > Maintenance & Modifications > Ultragauge installation
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
My gauge arrived today and is all fine but one thing I didn’t consider was the obdii plug. Am I missing something obvious or do I just need to cut a hole in the fuse box cover to make it fit as it were?
Thanks in advance….
Post #912690 16th Jul 2021 3:03pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Personally, I would not cut it - the cover is quite easy to remove.
You can also remove the obdii port from its bracket and kind of push it back in the dash with the untragauge plugged in, then close the cover Roaming around 🇳🇴🇨🇭
Post #912691 16th Jul 2021 3:06pm
scotty38
Thanks I’ll take another look at it and yep the cover comes off ok so was just speaking of refitting it with the gauge plugged in.
Post #912692 16th Jul 2021 3:10pm
scotty38
Marvellous thanks again and all done. The fuse box cover lives to fight another day…..
Post #912698 16th Jul 2021 3:31pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Just buy a 90 degree OBD extension cable - allows the fuse box lid to clip back as normal. Rgds.
Chris
Post #912712 16th Jul 2021 5:12pm
scotty38
Thanks I have since looked at those too.
Post #912713 16th Jul 2021 5:23pm
Greyman110
Very useful as I was just looking at how best to fit mine without damaging the fuse box cover.
Thanks! Thumbs Up
Post #912730 16th Jul 2021 7:46pm
