![]() | Home > Td5 > What is this noise? |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 105 ![]() ![]() ![]() |
Hello Forum,
My Defender has started making this whining noise, especially when cold... What do you think is causing it? Any advise appreciated. Alex sorry for the instagram link but I don't know how to post the video otherwise: https://www.instagram.com/p/CRYmcVyIy6Q/?u..._copy_link http://instagram.com/h4vou/ |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Power steering pump Roaming around 🇳🇴🇨ðŸ‡
Thank you... What do i need to do if anything?
A http://instagram.com/h4vou/ |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Wow I thought my pump was noisy, but its nothing compared to that! 2005 Td5 90 XS
1989 V8 110 CSW |
Many thanks for the help! What is the type of fluid I need to buy for a 2003 TD5? Best Alex http://instagram.com/h4vou/ |
![]() Click image to enlarge Would any of these work? A http://instagram.com/h4vou/ |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3481 ![]() ![]() ![]() |
liqui moly top tec 1200 atf should do the job.
I normally use ATF Dexron III 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
on its way thank you!
a http://instagram.com/h4vou/ |
